勾选后端分页,use_has_next没有给值
397 3
发表于 2025-3-20 10:23:16 | 查看全部 阅读模式
两个作业都勾选后端分页,报文中一个有给use_has_next入参值,一个没有给值
检查发现抛给T100的报文header里面的digi-host是不一样的,怀疑是不是因为这个导致use_has_next入参给值有差异
票据兑现产生的报文如下
    "digi-header": {
        "digi-reqid": "94376f04-d5c8-4354-9447-0e78d158fd20",
        "digi-host": {
            "prod": "ExecutionEngine",
            "ver": "1.0.0",
            "ip": "smartdata-test.apps.digiwincloudlocal.com.cn",
            "id": "ExecutionEngine",
            "uid": "ExecutionEngine",
            "lang": "zh_CN",
            "timestamp": "20250320101445812",
            "acct": "tiptop"
        "digi-service": {
            "prod": "T100",
            "name": "t100.oapi.electronic.bill.reconciliation.data.get",
            "ip": "10.40.40.18",
            "id": "t10tst",
            "uid": "T100_320",
            "tenant_id": "DWCK0420"
        "digi-datakey": {
            "taskType": "DATA_ENTRY",
            "taskCode": "DE_1264290210001da3",
            "EntId": "99",
            "appCode": "FIM"
    "digi-body": {
        "std_data": {
            "parameter": {
                "site_no": "",
                "reconciliation_code": "N",
                "trade_type": "5",
                "enterprise_no": "",
                "bill_source": "1",
                "is_digiwin_product": "Y",
                "call_id": "947d3833-2d97-443f-8b2b-20a1a8c15910"
票据查询产生的报文如下
    "digi-header": {
        "digi-reqid": "8c64ebc8-1251-4966-97c2-9773333c2020",
        "digi-host": {
            "prod": "Athena",
            "ver": "1.0",
            "ip": "esp-test.apps.digiwincloudlocal.com.cn",
            "id": "AgileInteraction",
            "uid": "agileinteraction",
            "lang": "zh_CN",
            "timestamp": "20250320100225926",
            "acct": "tiptop"
        "digi-service": {
            "prod": "T100",
            "id": "t10tst",
            "uid": "T100_320",
        "digi-datakey": {
            "taskCode": "DE_9b24a64210000c6f",
            "__PtxId": "HW_TEST_uibot-7q2p2^1742351445400^38773",
            "EntId": "99",
            "appCode": "FIM"
    "digi-body": {
        "std_data": {
            "parameter": {
                "generate_status": "2",
                "activityId": "DE_9b24a64210000c6f",
                "site_no": "",
                "trade_type": "6",
                "bill_source": "0",
                "page_no": 1,
                "use_has_next": true,
                "page_size": 50
目前定位是数据源的type不正确,可以先手动修改类型,改为ESP,保存发版,已会议沟通,演示全过程时没有复现问题,后续如有类似情况找到必现流程在沟通                                 登录/注册后可看大图
翁俊Lv.7 发表于 2025-3-20 10:26:55 | 查看全部
我先排查下问题
翁俊Lv.7 发表于 2025-3-20 15:22:35 | 查看全部
已提单排查问题,如其他作业有类似的问题,先暂停使用,等待本单排查结果
翁俊Lv.7 发表于 2025-3-20 19:09:19 | 查看全部
